Heck the subscriptions are confusing - if you want an annual personal/ Family one do you get the whole year for the same as normal or is the rate adjusted after 90 days even if you’ve paid!!!
The inadvertent click earlier I think was due to a ‘show/hide other plans’ hyperlink which collapses when removing HD leaving the mouse over sign-up!
Basically you have a subscription to Amazon Unlimited Music and it’s an extra £5 add-on for the HD option.
For Prime, if you are an existing/old standard Amazon Unlimited subscriber you get 90 days of HD for free but still have to pay your £7.99 standard fee.
If you’ve never had an Amazon Unlimited Music subscription you can get the whole thing for free for 90 days - saving £12.99 a month for Prime members, more for non-Prime members.
In case anyone wonders there is a desktop app for “HD/Ultra HD” audio on Mac and I assume PC - it’ll be interesting to see if this allows hi-res audio output over optical/SPDIF on suitably equipped computers directly to a DAC/streamer - I suspect not due to DRM issue if the stream could potentially be ‘intercepted’.
If you look at my screengrab above, there’s a checkbox for HD audio (shown) and I either unchecked that option or clicked on Hide Other Plans - the page immediately changes when you click either and I think my cursor must then have been over the Sign Up box and got accidentally clicked as list options disappeared and the box moved up. First World problems…
Might be worth a peek in the Settings as there are a few options for streaming/download quality and also ‘normalisation’ is automatically on.
Just seen a pop up to authorise my phone which I’ve never seen before and is confusing - I only have a single ‘AutoRip’ album purchase (one of hundreds) downloaded in my offline library which I can play without authorisation, but it seems I now have to authorise to add any others.
The T&Cs allow 10 devices to be authorised which seems generous but each can only be re-used after 180 days, and each authorisation can only be changed once - potentially you could run out of authorisations if you replace 10 original devices I assume from that.
@CrystalGipsy Thanks. I am currently streaming from the Android Amazon App to my Muso 2 via Chromcast. However when I click the HD or Ultra HD it tells me that it tells me “No information is available while casting”. I think the Chromcast on the Muso 2 is limited to 44.1/16 bit. Do you know?
Sorry no idea. Not sure ChromeCast is actually supported officially according to the blurb, likely it can’t display it as th device it’s running on is not the phone the apps on and gets no feedback. Chromecast should support up to 96/24 but it’s implementation differs per device and application as they don’t always advertise it’s capabilities correctly.
If you click the HD or Ultra HD icon as @CrystalGipsy mentioned the bit rate is displayed, if you click learn more allot of good info, chromecast does not give Ultra.
Clue here peeps is if your an AMAZON prime subscriber then this is an easy step, it just adds another reason to jump on the Prime bandwagon for the masses.
Pricing is simple to understand if you read the official press.
£12.99 if you already an Amazon subscriber , £14 .99 if you not.
So if you ready subscribe to Amazon Music which is £7.99 you get 90 days free access to the HD tier for the price of the basic sub. They are not going to give the whole sub for free.
If you have Prime and don’t have it have used Amazon Music you get the while shabang for 90 days as away to get new subs obviously.
If you don’t have any Amazon sub products then you pay £14.99 and get 90 days trial.
