The other IPA
Oops silly me . In that case l wholeheartedly agree!
Not heard from you in a whileâŠâŠwelcome back
Hi
I find pipe cleaners, the ones designed for smoking pipes!! are perfect for speaker sockets.
Ah so that what those are for. Now Iâm able to find them. Thanks.
I didnât insinuate you are a Dunce. Qtips are fine if you can see if any fluff has been left behind. I just wouldnât use them inside any female connectors where one canât as easily determine if fluff is left behindđ
You do know who Neil is?
Pipe cleaners are I have found much more useful.
Indeed a few are bundled along with some well known cleaning fluids.
Particularly in bending them to wrap around something or doubled over to achieve a particular thickness for a positive penetration.
Oops my bad, quite sorry!
Zumio x spirotip.
Has a little protruding actuator that jiggy jiggies.
Perhaps dipped in some product before getting in there ?
Yes Mr. Guinness. I certainly do. I also know for an absolute fact no one is perfect.
No problem Mr Soup.
Yet 53 posts later
Speaker sockets cleaned with Autosol. Autosol removed from speaker sockets with IPA.
Speaker plugs cleaned with IPA. Simple.
BlimeyâŠ
Must admit, it wouldnt have occurred to me to use Autosol as itâs a paste. But that is a lot of grunge!
(How many months/yearsâ worth?)
Would Anusol work?
Cheeky
Probably at least five years.
No. It shrinks the plugs.
