I thought that putting a better cable than the snaic cable supplied with the Naim equipment was better, given that the snaic still carries audio signal.
I think I may buy some Morgana cables from WitchHat to replace the Naim DIN-XLR cables that connect my SuperCap DR and 300DR. It’s a lot less costly than the SL cables, which are about $5k in the US.
If you look at the signal input sockets on the 282 you will see that the five little holes are in one half of a circle, 180 degrees. If you look at the holes on a Hicap socket you will see that they are more spread out, 240 degrees. So you cannot fit a Snaic in an input socket or an interconnect in a power socket.
Please respect forum rules. Discussion of unauthorised modifications to Naim equipment (which includes fake “SNAICs” etc…) is strictly forbidden. At best, they will not give you the performance Naim intended, and at worst, may well damage your Naim equipment. Thank you.
