I’ve asked this on a non hifi forum but am still confused.
I have hires flac files on a store connected to a PC. I currently stream via a pc based software, sqbx server, to a sqbx duet. The Duet feeds the qutest and on to the 252.
I want to replace the sqbx duet with a hi res steamer. I don’t need a pre-amp or a dac so what is there that will do the job? Obviously in the Naim world there is the Atom but I don’t need all of its functionality.
Aries would be a good choice and a G1 is what you want with a non-Auralic DAC. Currently around £2k in the UK and won’t need a wired connection if you have good WiFi. You can also use it with an external CD drive to play CDs if that’s of any interest.
Atom is a full system-in-a-Box, surely not, what you are searching for. (Transport, DAC, pre-/power-amp.)
Closest could be ND5XS2 (?), which has a DAC, but also digital-out, if you can connect it to the Qtest. (Others will know, or look yourself at the available connections.)
Ok, been looking through stuff. The Aries G1 looks a good shout from both a techie and a features point of view. Nothing is future proof but seems pretty up to date.
Any down sides? The only one I can immediately think of is expanding in to other rooms. Currently I can synch multiroom. I can’t see whether this can or not.
Look at the app side of things. From memory I think you have to use Apple to use the Aries, for me that is a no go. From a SQ perspective I enjoyed the G2, and I think the G1 gets pretty close.
Dont get to wild about the wordlentgh. The analog stages of a D/A is limited to 20 bits. Larger wordlength is only useful when mixing/tracking/editing.
Sample-rate is another matter. At 384kHz or higher you can remove the (digital) filters both in recording and replay and the reduction in smearing is worthwhile.
I understand, you want to continue using your existing DAC, correct?
Then don‘t get an Atom, it won’t support using an external DAC. (See comment above.)
