BBC Radio Streams - Important Information
If you are having difficulty accessing your BBC radio stream presets;
The BBC are on the final stages of moving to the token authenticated streams. For those that have had BBC stations stored in presets for a long time, you might need to browse to the BBC radio section, pick the station (it will hopefully play), then re-save the preset.
Steve Harris
Software Director
Naim Audio Ltd.
