Is anybody else having a problem with BBC radio? All BBC channels are down on my Naim devices. PC, mobile and steam radio all fine.
Tried router and Naim reboots.
Down too in South Oxfordshire. Other V-tuner stations are fine.
Iâm South Oxfordshire as well. Maybe we have been singled out.
As you, other V-tuner stations are fine.
Good to hear some good news for a change
I just posted a similar topic, but Iâm a newbie so my post isnât yet approved. In short, yes, indeed, Iâm experiencing the same issue. No BBC Radio stations are working at all.
I know that the BBC (in their infinite wisdom) is dropping support for players that take a direct feed this year. My BBC Radio feeds on my Linn streamers were working yesterday, evening this morning, but stopped working this afternoon. Linn is a casualty of the BBCâs slashing support for unsupported devices/partners, but thanks to Naimâs higher-ups, Naim is an approved provider of BBC Radio audio and work has been done to ensure that our presets continue to work.
So, why have the Naim BBC Radio stations suddenly stopped? Are there technical issues afoot? Could we have a post about this from Naim please?
Thank you.
Iâz Oxfordshyâr as well and my BBC iRadio HLS 339 is working just fine.
I blame SODC, (the pothole preservation society as they are known in these parts.
Iâm in Oxford, too. Are we part of some sinister experiment, I wonder?
No BBC stations on my Qb in Yorkshire, relieved to hear itâs not a problem with the unit.
This is strange, my service is still working fine
To be sure we are all on the same service, Iâm connected on Naim iRadio âNaims Choiceâ not vTuner or BBC.
Aha. Youâre onto something. I was using my presets (originally derived from Naimâs âBBC Radioâ section). If I go through Internet radio, BBC Radio then it all works.
Time to update my presets. I hadnât realised they were held separately; I had always assumed they were a shortcut.
BBC stations including BBC Radio Oxford are working on my Linn streamer using Linn Airable - not that I want to listen as I have better stations to listen to.
Iâve just discovered the same. Itâs the presets that arenât functioning.
I clear & renew my presets from time to time.
I get BBC from the Naims Choice section of iRadio, including the R.Paradise(s) & Naim Radio/Jazz.
Thanks for that advice. I do not actually have BBC listed under Naimâs Choice but it is further down the Internet Radio page. I have renewed all the BBC presets and all is well. Many thanks.
Ahh !!! Sorry my bad, yes the BBCâs have their own section.
If only. My Linn BBC Radio streams also stopped working at the same time. Full on pincer movement.
Buckingham as well.
My non naim bbc hls streams have stopped today.
Are you using Linn Airable radio?
Mine are all working.
Are you in UK?
