As always I’m looking for some advice.
I have uniti nova and MA silver 300 setup connected to my LG OLED TV.
I’m looking for a good quality BluRay player to play my collection of Blu-ray Discs, DVDs and very small collection of assorted songs on CD.
Budget upto 2k.
Im not that familiar with the range. They are sadly not made anymore so 2nd hand is your only option.
They are fantastic units and can play almost any disc you have.
Ebay or similar is worth a try.
You wont need to spend 2k either!
Agreed, although I think the UB9004 is better as a CD Player. For Bluray it has the same specs and features . I was willing to pay double for the build quality and looks.
I’m sure it is a better CD player (and probably has the edge with Blu-ray as well). I was sorely tempted by the UB9000 (as it was when I was looking for a 4k player), however Sevenoaks Sound and Vision had a secret £100-off offer on the UB820 which made it impossible to ignore at £199…
I know which one I would take
The Reavon is surely a very good option but the higher end Modell with the analogue outputs is almost twice as expensive as the Panasonic in Germany
Hard to argue with an Oppo, just hard to pay the price they are asking for them used. I have a 203 since it was released with no complaints. Paid 600 US for it new, i see them now for up to 1500 used.
