Thanks for the update. So glad that this fiasco will be over in 5 days.
Donât know about your,but I donât believe it will be fixed this month sorry
Probably Steve meant this year and not this month
Firmware without rollback and more than 4 month to fix is a no go. Definitely my last Naim
Steve, can we request software dowgrade? The software version before upgrade worked just well. Could you please send a link or redirect us to download server or smth.
Thanks!
How much longer? Please manâŚ
Hi,
An option to downgrade to any version of the firmware the owner deem suitable for his usage is a Brilliant Idea.
Different Folks, Different Strokes.
Regards Wayne
FWIW, hands are likely tied here as I donât think the licensing agreements with 3rd party streaming services allow this.
Would it be possible to get an update, please? It feels like itâs not recognised that this is a use-case breaking regression. 5 months and counting to fixâŚ
Hi guys,
The new release is having the paperwork finalised and then it will go live.
Based on we typically donât release new code at the end of the week (customer/dealer support), itâs likely to go live next week now.
Best regards
Steve Harris
Software Director
Naim Audio Ltd.
Thanks for the update Steve.
Do you have the remote control issue after update? If I stream tidal or spotify, the next song button doesnât do anything on remote controller
Thanks.
Hi Richard,
Not sure what got fixed, but AirPlay on my MacBook still has a 2 seconds lag and I cannot stream any movies. When I use Bluetooth instead, my Qb2 offs itself after playing for a few minutes.
Has anyone else similar issues?
Thank you,
Marko.
AirPlay 1 always had 2 seconds buffering / delay.
(I worked around that years ago by using VLC and setting a respective -2 seconds offset while doing so.)
Itâs setting an offset on the audio track compared to the video stream, IIRC.
Iâm a bit late in this thread, but I can confirm that 4.3.1.6471 fixes the Bluetooth delay problem between my iPad and the Qb2.
