last night I spent some time with the new 282 and decided to listen to the difference between the rca input vs the din. I had been using a chord shawline with a mayware din adaptor and tried just using the rca aux2 instead. although adaptors are not the best solution I had noticed that even with the adaptor the sound was better. mainly noticed to be in the bottom end ie through the rca there wasnāt as much and it lost its drive compared. altogether though im very happy with the 282 and it is only 2 weeks old from new so is still going thru its break-in time
I have to say with my then Dyna Contour 1.8s I thought the 200 more rhythmic and yes musical than with the 250-2 which I found laden. 250 DR though massively different.
