Can the NAIM R-COM also control the Naim DAC? … and have I understood correctly that he cannot control the streamer?
See here;
Note that you’ll need a later NARCOM.
I have pre-amp Naim NAC 202.
Then the Narcom that came with the NAC202 may very well be able to change the inputs on the NAIM DAC. Be sure the Narcom softkey is set to PRE and use the numerical keypad to switch the analogue and digital inputs.
If you use a streamer (NDX or similar) it’s worth taking an advantage of system automation built in. This will also change inputs on the nDAC.
If you have a streamer with an FM module - FM signal will also be processed via nDAC (magic :))
