CB Nap160 Replacement Bulb
The on/off switch bulb has gone on my CB Nap160 - can anyone recommend a suitable replacement please, ideally a compatible longer life LED type perhaps ??
TIA
See here;
These exist and are available. I fitted one & it worked fine.
Probably best to get advice from @NeilS here…
Following, as I need one too, for a Bolt Down version.
They are available from Farnell in the UK. Search for 1505465W3D.
I have them in my 135s.
i am not sure that the “bulb” for the NAP160 is the same than thoose for NAP135/NAP250 (that might be bigger)
The switch is the same - AFAIK - so I would expect the bulb to be the same too.
YMMV, etc
depending if it’s a CB or a BU.
i think that thoose for 160BU and 250BU a shorter lamp is required
Mine went too last year some time. Tom Tom Audio stock them, though I can’t remember which one is correct for the CB160, but they will be able to advise you.
Incidentally before I got round to ordering one the bulb started working again after I had to dismantle my system for some renovation work. It has now stopped working again but I am happy with it and haven’t bothered replacing it!
The sound is better without the light, if that matters.
