“If it was not you in some other post, there is at least one other person who had the CDS3 puck problem. If I remember correctly, the CDS3 puck has rubbery spots at the bottom that can get depressed over time, leading to this. The other guy always left a CD in the tray for extra dust protection, with the puck in place, but switching between two pucks solved it (to give the rubbery spots time to expand again)”
My CDS3 was serviced relatively recently due to failure of the laser mech. It was replaced by a different mech (I don’t recall the numbers, VAM something or other) that uses a magnitic puck without the rubber bits.
The original pucks could easily be revitalised by rotating the little rubber bits a bit. I wouldn’t worry about pucks!
Thats interesting. I keep a spare puck for my CDS3 (though if you don’t leave a disk in the machine, the pucks last for years) and plan to send it for service later this year. I could be left with a redundant brand new puck if the mech’ is changed - a whole 15 pounds down the drain !
Even a luddite like myself recognizes that the technology moves on but just as Naim make phonostages for vinyl users why not introduce a dedicated high end CD transport to plug into the network planners.
We can service all Naim CD players - as in replace the capacitors.
The original CDS, CDI, CD2 & CD3 are getting very dodgy now in terms of mechanism repairs.
We only tend to see these players with DAC failures (for example) & the shipping hasn’t been kind to the mechs. We have yet to say “sorry - can’t be done” but it is definitely on the horizon. As has already been said, don’t ship these players unnecessarily!
All other players with disc reading issues can still be repaired at this time.
The early CDX-2 & CDS3 with VAM1250 transports can be updated to VAM1202 which would mean a new spec clamp (puck 5) without rubbers.
Had my CDS3 serviced not long ago by Naim VAM 1250 removed, capacitors replaced new logo and new VAM 1205. The first replacement failed Error on display however it was returned new upgraded mechanism (I believe) superb and yes it sounds so much better than the failed mech. Brilliant thanks Naim
Thank you. I came very close to traveling across half of Europe, Corona or not, to pick it up. I guess it will be shipped after all, and I am relieved that I don’t have to make the trip, but won’t sleep well until it’s here. And yes, I did remind the seller to be mindful with the transport bolts!
But I am getting ahead of myself, it’s not paid yet and not here yet. Better to keep hopes in check until then.
Very wise - the transit bolts are absolutely critical.
With a player at this level, I would even ask for photographic evidence that they are fitted before the seller sends it anywhere.
That is good to know. I bought a very early CDS3 in ‘04. It still sounds great and works just fine. Neither it or it’s XPS have been serviced yet but it’s nice to have confidence in it for a Few more years.
I’m very much on the same wavelength as much of you - if I can fix a player and delight an owner, I’ve done my job. At the end of the day, that is what I’m here for.
Every job I touch, I want the owner of that piece of equipment to be overjoyed when they get it back.
It’s just what I do.
Hi Neil if you did service my CDS3 about 2 months ago and sealed it with blue plastic over the door thank you very Sir. What a professional job the replacement mech is, superb. I would say it’s more detailed than the original VAM 1250
I hope Neil might look back here because I have a query about an issue relating to the CD555 which came up on another thread recently. It’s about the plastic spindle on which the CD locates before it is clamped by the puck (I’m not sure that spindle is quite the right word as it is the plastic piece on the end of the rotating spine of the motor). I occasionally had a problem with disc reading that I eventually established was caused by some CDs not fitting snugly on the spindle. Having seen the other thread, I now realise that this is probably caused by the fact that there is a small crack in the spindle, which presumably makes it minimally enlarged and prevents some CDs from sitting correctly. In the other thread there were owners whose spindle not only cracked but fell apart. There was some ambiguity about whether this required the replacement of the complete mech or if the plastic spindle could be replaced. I am being very cautious in placing CDs but some do require a little pressure to locate correctly and I am worried that eventually the crack will lead to the spindle falling apart. If so what are the repair options? Thanks, Clive
