Finally after weeks of should I or shouldnt I. I have took the plunge and purchased a Naim Hicap DR for use with my Nait XS2 integrated.
This has used up a nice chunk of my current funds and have now realised I also need the 4 pin Din cable.
Does this absolutely have to be the naim Snaic 4 Pin or are there cheaper alternatives?.
An alternative would just be short term with the idea of eventually purchasing a cable of the naim variety. When funds and my wife recover.
Please note forum rules with regard to discussion of unauthorised modifications to Naim equipment (which includes Fake SNAICs).
If you can’t afford a new SNAIC then look for secondhand. Be careful not to buy a fake SNAIC - at best performance will not be as Naim intended and at worst they may damage your equipment.
TomTom is a good shout TBC. Any Naim dealer offering classic and above kit (check Naim website) are likely to be able to help. It’s a small and robust enough item to post cheaply, so any dealer Nationwide is a possible source for you.
Very fishy. I think we’re looking in different places…
I’m going to stop looking at the classifieds as this can rapidly lead into temptation and I really don’t need a pair of Impulse H2 speakers
