Hi
To bad, that my topic has been closed (update supercap on prefix).
I remembered that Richard (@Richard.Dane) adviced to use the grey interconnect 4 to 5 instead of the hiline. I did so and it is really good. I also prefer the lavender over the hiline 5 to 5.
I now found a used chord Sarum super aray 4 to 5.
Is this an option or can I assume that it is also „overdone“ as the hiline.
Hi Chris, I’ve actually seen some Chord I/C cables for connecting Naim streamer to preamp which are just 3 pin din to 3 pin din. Was wondering why just 3 pins if the Naim ones use 5.
That’s what I als thought. But a chord (which has 3 pins instead of 5) is in really a different price range. 10 times or even more. Don’t know the price for a new cord Sarum super aray cable.
Nice as the standard Lavender cable is, the upgrade to Sarum Super Aray is huge, not just in terms of detail but a sense of increased realism of sounds. The musical engagement to the listener is a sizeable improvement. (CDS3 - 552)
Also, about 4 years ago the Chord Sarum SA was superseded by Sarum T.
Although both these cables retail(ed) at new price around the £2k mark, the Super Aray can be found at lower costs due to being ‘old-new’ stock, pre-owed or trade-ins so should be far less than £2k, so better value for money too
Thanks!
There is an offer for around 600 Euro for a super aray 4 to 5 (or 3).
Price is good, but I am very careful as I had recent experience with preferring the prefix over superline. Maybe me ears are only keen to Vintage Naim sound.
Do not hope the cord brings in the same difference as superline did.
I haven’t seen this Chord recommendations, can you point me in the right direction.
However, sceptically, I feel cable a company’s main objective is to sell cable, and a longer length is more revenue to them than is a shorter cable.
My electric engineering brain says if an IC cable has any effect on sound, then minimising whatever it is that does this has to be good
As a result of this thinking, I’ve built my own, I used a cable with lowest C, L & R as possible & made to fit the distance between components - my shortest is 28cm.
The sound of my cables to me is as good if not better than a comparison with a few notable others, including HiLine.
Just a thought ….
“ Standard length of Clearway DIN cables is 1m. Many years ago we established that shorter length cables have a detrimental effect on Naim Audio amplifiers. Longer custom lengths are not a problem.”
From this I concluded an extra .5m couldn’t hurt, & cost only another $5.
OK I’ve already seen that, but sadly as is often the case, no supporting evidence.
As an electrical engineer, my logic says short cables have less of the CL&R that can affect the integrity of the source signal.
And as I said earlier, the more cable they sell, as in longer cables, the more money they make.
