Hi all, first post here and it’s a question about how to connect my new RIAA to my amp: what is the best way to connect a Stageline to a Supernait 2?
I have a free slot on my FlatCap XS that I was thinking of using to power the RIAA - or would i benefit even more if I power it directly from the Supernait 2?
Hi all,
Maybe I should have opened a new discussion but topic seems to be the same…
I run XS2 with Hicap and just bought Stageline N with two sockets.
Should I use the 5 pin cable to power the Stage through the Hicap?
If you are referring to the Snaic5 between the Stageline and the amp, the band goes at the Stageline end, as shown in the manual. The band always goes at the music source.
I actually swapped between phono-stage of Music-Fidelity and the Naim Stageline, thinking that, having XS2 with HC2, the stageline should be the way to go.
First impression is that the sound is much lower than before…
is it because the Stageline doesn’t have its own power source?
What do you think it means that the volume is lower comparing to the previous phono-stage?
Does it mean that I should connect the Stageline to the HC2 and use another SNAIC to connect the HC2 to the XS2?
@Ronmaik however you power the Stageline I wouldn’t expect any difference in output level/gain whether powered by a Flatcap, Hicap or a powered aux socket, they should all be providing the same electrical supply, even if their regulation type/quality/noise differed. Certainly nothing to make them louder/quieter.
I suspect the difference between the MF and Naim stages is just a gain difference. From Naim the Stageline N gain is 35dB at 1kHz. I’d check the gain of the MF stage to check if it is higher. (Including your system spec in your profile really helps!)
FWIW I crank the volume up a fair bit when listening to vinyl Goldring 1042 into Stageline N into XS3 into Neat Motive XS3 compared to CD or streaming sources.
The Stageline N is an excellent MM stage but sound-wise I found it is on the dark and earthy side so you need to match with a suitably bright and lively cartridge to get the best match.
This is what it says on the Goldring site:
Goldring 2000 series cartridges should be used with the standard moving magnet phono input of an integrated amplifier…
What does it mean in regards to XS2/HC2/Stageline?..
Shoud I buy XS3 just for the Goldring
