There are three types of 5-Pin DIN outs, 180 degrees, 240 degrees and 270 degrees. Naim have a 180 degree DIN to RCA. We need a 240 degree DIN to RCA . I have both. The 240 degree works with TAPE our, A/V out and Aux 2 out (I think).
I was going to have my Naim/Chord dealer have Chord make me up a cable but then I found the T.P. one. I didn’t want to spend too much on this application because there isn’t much call for it and it would be difficult to sell.
I was fortunate to find it. It will replace a Chord Sarum T I was using from the ND555. This eliminates the need to switch the output from the ND555 when I wanted to switch from speakers to headphones. I could have both DIN and RCA active at the same time but I found that it’s true that having both active at the same time has a negative effect on SQ. I discovered that fact accidentally when I did something that increased the SQ noticably. It took me a while to realize what it was that was the cause.
