I didn’t know the 333 could vary the output level but that’s great to see. There are still plenty of input stages around that can overload on CD standard voltages or, slightly less seriously, that are not at their best on inputs that high. Sadly it doesn’t obviate the need for a pre.
There’s so much muck in the air and on ground lines these days that signal conditioning is now more of a requirement than a luxury. That time-aligned filter that first came out on the 72 was a great idea and I expect is now baked into the Naim sound to the point that it’s probably now necessary to have it to get the same sound they get at the factory.
Personally I’m keener on even more aggresive filtering than Naim do and definitely don’t subscribe to the “infinite bandwidth” credo some manufacturers think is needed for virgin purity. But even if you don’t open up the bandwidth to AM radio frequencies, which many do, nearly all the components in these amps are capable of going out to tens of MHz, if not several hundreds. Signals at these frequencies will affect the behaviour at the PN junctions, and most electronic engineers will throw up their hands if asked to predict what is likely to be going on. So best not to have them at all.
The bandwidth of the 333 is likely to be narrow enough to be acceptable to the power amps (though that may actually not be the case with higher res material - I don’t know) and we know that Naim do say not to send their power amps signals that are outside their remit, but it’s what it might have picked up on the way - and the fact that it hasn’t been washed, dressed and tidied up - that is going to mean that the output is slightly less than optimal. That may not show up all the time but it’s going to be somewhere between not getting everything the product can do and that grinding descent into just not listening to it because it’s not hitting the spot.
So, yeah, definitely get the pre-amp. And I might even go so far as to say, trust Naim! There may be a few electronics engineers out there who are better equipped to do the job, but none of them has spent as much time as Naim has trying to hit that spot, for you. I have a genuine respect for Naim Audio and none of it is fanboy stuff - though of course it was in the beginning.
