My 2960 is a new white one and my 2940 is an old blue one - but it sounds wonderful.
I had to ‘tune it up’ to get it to sing - that done it stays on-song fine.
The tuning-up - apart from carefully finding correct support for the two switches - was to choose the Ethernet cables that gave me what I wanted. It was very important and some cables gave a very poor performance.
Mine are: from router a very very long Cat5e nothing special - 2940 - 1.5m AQ Cinnamon - 2960 - 1.5m KabelDirekt Cat6 - Melco -1.5m AQ Vodka - ND555.
I’d not saying this particular combo is best, but that the permutation and combination with the various boxes greatly tunes the SQ.
For example - remove the Cat6 and replace with cat5e or Cat7 and awful oppressive sound.
You have to be prepared to have a selection of different patch-cords and sit and play and listen to what it all does.
The ‘one best cable’ idea is dead as far as I’m concerned - I went in circles chasing that and instead found my answer.
But all this could possibly be popped into a suitably expensive switch box and sound better so that may be the better solution in the end.
I’ve been listening to all my albums like they are new - incredibly quiet backgrounds now with lots more musical detail retrieved and griping timing that keeps me memorized into the track - then the next.
And this has nothing to do with special programming of switches - that may do other things but not got onto that yet as it seems to me the main benefit is in whatever this breaking of the network into smaller segments is doing - however it is doing it.
DB.
