@Darkebear,ā¦This is interesting,.what feet have you come up with,that is best on your Cisco-switch in your system.?
A very āAttention To Detailā,.knowledgeable friend of mine in Gothenburg,bought some different cheap rubber-feet to test during his Cisco.
He liked these best (see picture below),.under his Cisco,in his Hifi-rack,.in his system.
ā¢ But you see above Darkebear,.everyone is not as interested in optimizing their system .
Do you have a picture of which feet you use for your Cisco.?
My friend from Gothenburg,.is one of the best known in Naim,Linn and Lejonklouās Hifi-products in Sweden.
He has had Linnās and Naimās previously heaviest active-system,.nowadays he runs with Lejonklouās best products.
Here below is a picture of the Hifi-racks that he now uses,and on these he has listened,.that the small rubber feet in the picture above are the best.
These swedish racks are called Harmony,.and cost in the best version (you see in the picture) as a Naim Fraim,they are very good.
He was also the first in Sweden to try to find the best ethernet-cables for soundquality.
And also discovered that the direction of the ehternet-cable was significant for the soundquality,.this was about 12-13 years ago.
As you understand,.he got a lot of criticism on various Swedish forums,and was called crazy etc,etcā¦
So not much has changed on the forums on these issues on these 12-13years.
And with hindsight,.he had of course right.
Heās like me,.and also you seem to be.
Extreme geeks,.when it comes to āAttention To Detailā in system-optimization.
He and some of the group also designed a Nas,.which for many years was counted as Swedenās best musical Nas on Lejonklouās forum.
And also on the Swedish Linn forum Selleri.
Well,.this was some thoughts late at nightā¦
Good Night.
Ps: The only thing I do not like about,with his installation in the picture,.is that he uses Linn Skeet.
In 10 cases of 10,.when I tested and compared so is Naimās Chips betterā¦on all surfaces.
Skeet is only good when making a tuning of your loudspeakers.
After that,.they should be removed,put at the bottom of a box and be forgotten.
/Pederš
