I have also become disillusioned with high-end cables from those I have tried (and not just Ethernet cables, either). On the Ethernet front I was split between the BJC Cat6a and DC CatSnake Cat5e, eventually preferring the latter as more balanced and textured although less detailed, but I think these DC Cat6a take things up a level all round. In addition to the above, they also capture decay much better, but in general are so well-balanced that it’s easy to start taking them for granted and just listen to the music. But a quick swap back quickly puts things back into perspective.
Now that the EtherRegens are more or thoroughly burnt in, I will at some point re-evaluate the difference between 1 and 2. I also want to check back in on the difference between the Powerigel and Sean Jacobs Powerblack Block. I have a DC3-4 hybrid on order from him for the switches and router to finish things off. Unfortunately there is no way I could shoehorn in the full DC4 box.
I take it the 6a cables you have are not the ones I could order straight off the designacable website that seem to come with metal shrouded plugs, though still Belden 1303E cable. Have you the spec to hand?
Should we speak about ASSD : Anti Social Scientific Disorder = syndrome of claiming that others are wrong because my scientific theory says the contrary. “ No, you should not hear that because science says that”. “ so your perception is very probably a brain fooled one”
How about adding ASED: Anti Social Engineering Disorder = adding unnecessary engineering features to make a product appear more sophisticated.
Or how about adding ASMD: Anti Social Marketing Disorder = taking a product designed through ASED and selling it for a much inflated price as it superficially appears to be more sophisticated.
Hypotheses formed from this thread, yes entirely.
Hypotheses formed from combinations of well established scientific theory - now that’s a different matter.
Now that I’ve confirmed the POE works well using a 8PT --> 8TT I’m considering getting another 8PT as a back up and may even consider a third switch to separate the NAS from the streamer layer.
Can a 8PT send POE to another 8PT and send POE to the last 8TT in the sequence?
To illustrate: 8PT (plugged into the wall)–>8PT (POE/no PS)–>8TT(POE/no PS)
No that won’t work… you will exceed the first PoE power budget even if PoE+. PoE is not really designed to be used like that either.
Don’t understand your point of separating the NAS from the streamer ‘layer’. They are all by definition in the same layer (layer 2 network) and common broadcast domain. UPnP requires all devices to be in the same layer/subnet, unless you are going to use advanced config with multicast routing and helpers.
@Xanthe,…Hi again,.I respect and accept your answer,but I still think we should be careful about using such formulations.
As I have said before,.we are from different countries, different cultures, different generations.
So it can easily be misunderstood and create irritation,which it now did a little bit.
But thank you for explaining what you meant.
