Firmware 3.8 Release
For users of Naim Uniti Atom, Uniti Atom Headphone Edition, Uniti Star, Uniti Nova, ND5 XS 2, NDX 2 and ND 555
We are pleased to offer Firmware 3.8, which offers a range of improvements and minor bug fixes. It also fully prepares these products for the upcoming change in TIDAL authentication – so is an essential upgrade for anyone streaming TIDAL.
The update will be available from today, and is easily installed via the Naim App: please ensure you are running the latest version: 2.22 (Android devices) or 5.22 (Apple iOS devices) or greater.
Improved:
  • System automation - preamp input is selected when changing source, content and transport state
  • Updated Roon implementation
  • Updated AirPlay implementation
  • CD Ripping - analysis carried out on FLAC rips and indication given in the rip monitor if an error is detected
  • CD Ripping – ripping will now only start if music store has sufficient space, and provide an error message if not. This improves previous situation where rips could start then fail
Fixes:
  • Multiroom - New platform device could not connect to legacy master device after being disconnected
  • Multiroom - Intermittent small burst of audio on master device when changing to track of a different sample rate
  • Internet radio stations which use HTTPS would fail to play
  • USB - .m3u playlists would fail to play
  • Bluetooth input did not auto select at start of playback
  • Front panel - Artwork from some services would fail to load
  • Front panel - Display off when not playing timer was not reset on standby cycle
  • Front panel - Disabled external inputs were shown under the inputs menu
  • Bluetooth - no metadata show on now playing after input auto select
  • Tidal favourites could fail to sync on some accounts
  • Display - processing of very large artwork images could cause a crash
  • Roon - progress bar was shown on the front panel for live radio stations
  • Front Panel - Period of black screen on track transitions as new artwork loads
  • Playing a large playlist could result in only the first 15 tracks being queued
  • Rovi lookup would fail on some CDs (Uniti Star only)
