Firmware 4.8 update not working - Mac
Hi all - just got a S/H NAC 172 that’s running FW 4.7; trying to update to 4.8 so I can log into Tidal. But the Naim software seems to be out of date / not able to run on a Mac? See the error message below:
Can’t be opened because Apple can’t check it for malicious software? And needs to be updated by the developer…Anybody else get the same thing, or do I have a security setting on my Mac that’s preventing just me from opening??
@Richard.Dane - not sure if this is the right forum, or if you want to move to the tech/Q&A section…
If anybody has some input here, would be greatly appreciated. Thx!
Yep an amended security setting is required on a Mac.
Did you do a forum search, this one might help! Mac will not open new firmware updating app
Yep, just found this - thanks
Got it running - was super easy; took all of 10 minutes
