This is F.Y.I. for FM radio forum’ites ……
I’ve now finished a cleanup of TV and FM stuff
TV first, after the 2022 clearance for 5G, the old attic mounted Group W log periodic & its LTE filter is replaced with a Group K log periodic.
Sony says 100% signal & quality.
My FM reception is via an attic mounted Ron Smith G14 that’s pointing at midpoint between the line-of-sight heading to the main regional transmitter and the hill-shadowed heading to the low power local transmitter. This is over a beamwidth that exceeds the 55 degree acceptance angle of the G14.
The signal from the main regional 46kW transmitter at only 5.6km distance is strong and faultless, the problem is with the local 0.3kW transmitter with low signal levels giving poor SQ and intermittent stereo breakup.
What to do ??? thinking caps on and experimental mode engaged …. Ron Smith Galaxies, and many/most other FM aerials don’t include a balun as its judged that with a reasonable dipole to coax impedance match they operate to an acceptable level without a balun. However, without a balun, the coaxial outer shield becomes an unwanted extension of the antenna, carries common-mode current & less than optimal efficiency.
So maybe a balun experiment … I looked up the candidates for a 1:1 balun/choke and selected, made and installed a ferrite sleeve choke known as a Maxwell W2DU. This creates a high-impedance interface between antenna and coax shield & forces current at the antenna terminals to be equal in magnitude & opposite in phase giving the antenna balance and symmetry.
Despite the wide beamwidth and installed in the attic, it delivers an exellent signal from the powerful regional transmitter, and with the Maxwell choke installed, the low power signal from the local transmitter is now very listenable with near-full quieting, no audible hiss and no uninterrupted stereo.
Not easy for you folks with outside aerials, but if yours in in the attic, maybe something to think about.
I just wish I hadn’t sold off my old signal strength meter and was able to get some real numbers.
