I can’t imagine the use of multiple servers was ever considered when Naim developed them. So yes, I think it’s likely that you would need to run only one of them at a time. Do you need to run them both simultaneously?
I’m not sure if a restore from backup would work for a music store that was created by a different device? I guess the easy option is to copy the backup folder from the NAS to the US downloads folder.
Good luck! If I were you I would copy batches of music if you do it manually, rather than doing the whole library in one go. Then it it stalls or loses connection it’s a much smaller mess to sort out.
Dave - if you know and follow the logic of the filing system used by HDX / UnitiServer, it is possible to manually move ripped files
It was traditionally discouraged by NAIM (for very good reasons).
I’ve done this on many occasions and the process works.
Essentially you can load up the library from HDX to UnitiServe, in a process that resembles drag-and-drop using your Mac.
The problem I have is that on my MacBook, Finder will display only one or the other of the HDX and Unitiserve, depending on which one is hooked into my switch.
If they’re both connected, then I can see the HDX but not the Userve. The weird thing is that they each show up under the same IP address, though I’m not sufficiently network savvy to know whether or not this matters.
It looks as if I may have to transfer my music to the Unitiserve from my NAS, unless I can figure out how to have both the Unitiserve and the HDX displayed at the same time, and, as you say, drag and drop.
If they both appear under the same IP address, then it will never work for you. This is the sort of problem that arises when people start fixing IP addresses instead of leaving it to DHCP.
I think you really need to reset them both to DHCP or if you insist, set them to different fixed IPs.
Hey David
It’s been an extremely bussy couple of years - decided to set up my own business a year ago.
Nothing better than doing it in the middle of a global pandemic
Funny enough… it seems to have died overnight… shutting it down and re-starting works well (as in - UnitiServe does not get stuck on the blinking green logo).
But my network stopped ‘seeing it’… I will re-set the switch later on, but have a feeling it won’t cure the problem (I use type of Cisco switch, which in theory should not require any re-starts).
