How do I go about adding a good qualty headphone to my Naim NAP 250-DR power amp and NAC- 285 pre amp? I am guessing I would need a dedicated headphone Amp pluged into the pre Amp. Which models would you recomend?
The FAQ to the rescue…
Hi Tyendra325,
I have a 282/250DR set-up but have approached the headphone connection slightly differently to that which Richard D has suggested. My front end is an NDX2 and I utilise both outlets - the DIN output goes into the 282/250DR/speakers and the RCA output goes into a Violectric V280 headphone amp. F.Y.I. my headphones are Meze Empyreans. For me this setup works just great.
The Violectric V280 is a great headphone amp in my opinion, but as ever, its a personal choice.
If you do this be sure to disable the unused output - performance is impaired somewhat with both source outputs enabled.
Just had my old olive Headline serviced. It was in the loft and unloved I am sad to say. Bought some cheap Sennheisers and now have the option to listen on cans again.
A second hand Headline will keep it Naim based and inexpensive. Adding the Atom HE a more expensive option. Or get a 222…
