Question is, should I add a Hi-cap DR (on useful sale at moment) or is there anything else I should be directing my upgrade bug monies to? If former, have others done this and how much of a benefit was it?
I fully agree, although i have an SN2. The SN2 on it’s own is very very good, but with a Hi-Cap DR becomes a transformed animal altogether.
Do it, you will never regret it.
I’d suggest you try it first, as not everyone prefers the sound with the Hicap added. By NAS xs2, do you mean ND5XS2? Before adding a Hicap, I’d like to hear what difference an NDX2 makes, or alternatively adding a secondhand Naim nDac.
A hicap does not harm but you have a good space there which may make improvements and details inaudible. Details is what hicap improve amps on. Are you sure your room works good enough?
I did have the SN3 running solo whilst HCDR was serviced, and it was still a cracking amp, but once returned and refreshed it went back in and just adds that little bit more.
Think everything just flows a bit more effortlessly.
I have mixed feelings about adding a HiCap to my Supernait 1. On the one hand, I know what the PSU does to it, on the other hand it’s true about not everybody loving the effect. If I remember correctly, years ago you were doubtful about adding a HiCap to a CD5(x), suggesting that a FC2(x) gave better balance. Sometimes a HiCap may seem to ‘turbo charge’ (your words) a unit. I’ve had similar feelings a couple of days ago listening to a SN3 with and without HCDR; the PSU seemed to add ‘flesh’, to ‘saturate’ colours, to bring everything more upfront. I wasn’t sure I liked it. Yet, I personally find it very difficult to leave an empty PSU socket alone.
Once I tried a dual-railed SNAPS on my second or third SN instead of a HiCap. The SNAPS used a NAP110’s transformer by design, had only one large-ish capacitor and a simpler version of LM317 regulators. I found it brought benefits in terms of timbre more than of detail and/or presence. It seemed to give the SN a more refined, nuanced and less muscular voice overall. I’ve always found the SNAPS an extremely wise compromise between a FC - not much of an addition to a SN - and a HiCap. If I found one again, I’d surely use it directly on my Stageline, on which it seems perfect to me.
But of course, a SN3 needs a DR-ed PSU to fully benefit from it.
Pointless Post I know, but I like telling of my short life with SNAPSs.
Hi Ardbeg10y
I would say that the room does not do justice at the moment as speaker positioning is not how should be, but I have plans to rectify that. Also, is a fairly ‘bright’ space (ie with hardwood flooring and rug, albeit with quite a few curtains) so could probably do with some more absorption to reduce the reverberation time.
The room proper is c.28m2 (with rest around corner in L shape), so listening distances not too much.
In perfect world would have dedicated listening room, but upgrade budget in no way able to find construction of that .
Hi MaxBertola
Lots to ponder. (Think was someone else you recalled? I do have a CD5i in the loft, but should probably sell as us the ND5 xs2 for digital source material, ie all ripped to my NAS)
Trouble is you can listen to a shop demo and not fully appreciate long term. Even if take a loan one for a week or two, need to listen to for probably longer.
It did occur to me that could probably buy one (at current sale price), use for a few months, and then if not to taste sell again as near new and have lost very little.
I started out with a Basik arm on my first LP12, and the best thing I ever did to it was change it for an Ittok. If vinyl is a priority for you I would consider this.
If you want to improve the digital side, an NDX2 would be a nice step up, or keep the ND5 and upgrade the DAC.
The advantage of the Hicap, of course, is that if you like what it does (and I think you really need to live with one for a while to decide) it benefits any source.
This mirrors my experience. While my HiCapDr was being serviced I thought maybe I don’t need it and should sell it, however once I put it back in my system the magic returned. I think the SN3 is so good I’d wait until you have everything else sorted then add a HiCapDr (however if the price is right buy it now with confidence )
Can’t go wrong with HCDR at a good price e.g… 60% of current rrp or less
And only accept one if it doesn’t hum in your environment (some do, some less so). Otherwise, the hum may outweigh the benefits!
