That’s about it. Use socket 5 on the Supercap rather than socket 3, as this one is the closest to the Burndy socket which is taking the signal to the Snaxo.
Remember to put the paddle shaped link plug back in to Link 2 on the 282 as you’ll now only have one SNAIC5 connected when using the Hicap to power the 282.
DG I was going to post another pic, but the old connections guide doesn’t show everything and not exactly what you need.
I’ve been checking this because I was initially confused by the reference to two connections to supercap as you wrote
Supercap Large Power and Inputs Socket (Burndy) to SNAXO PSU and inputs Socket (power and signal)
I follow the source through each of the boxes, going only in one direction. I’m being cautious.
I think you are correct - with the socket change @james_n suggets.
So maybe think of or write:-
282 to Hcap - the connnections look ok and as james points out, connect only one snaic
Hcap to Scap is again a single snaic connection
Scap to Snaxo is a single connection and the only burndy - with link plug removed
DG if you think configuring active is somewhat confusing, then I summarise a comment made earlier the year from a Naim member of staff no less, who suggested he cursed when setting an active setup in the listening room; hence part of my earlier comment. I’m a great believer in labelling each and every cable, also helps with getting the direction correct (well not perhaps the power).
IIRC the scap is more fully used via the burndy supplying the snaxo. 82/282 doesn’t use a burndy, when connected to a scap, so only part of the scap is used. Scap > snaxo then more of the supply rails are used. (With a 252 for example, a supercap does use a burndy connection.) @Richard.Dane will no doubt explain better than I.
There is certainly a school of thought to suggest this - I’ve not yet got around to trying it primarily as I don’t have the appropriate Burndy for th Snaxo 242 but I coul just try a SNAIC.
The 82/282 can utilise secondary power from certain power amps such as a NAP140/180 (but not NAP250 or higher), 1xFC, 1xHC, 2xHC and 1xSC.
When powered by a Pwr Amp, the (2)82 receives one +24V DC secondary supply.
When powered by 1xHC, or 1xFC, the (2)82 receives two +24V DC secondary supplies.
When powered by 2xHC (or even, I suppose 2xFC), the (2)82 receives four +24V DC secondary supplies.
When powered by 1xSC, the (2)82 receives four +24V DC secondary supplies.
The generally held wisdom regarding Naim preamps is that more secondary supplies the better, and results in better SQ.
It is generally accepted (but not universally so) that 2xHC (over 1xHC) is a significant upgrade in SQ.
It is less clear clear between 2xHC & 1xSC…but again opinions do vary.
I always found the sound performance of one Supercap (fed with both 2 x24V supplies) on the NAC282 to definitely trump two Hicaps (giving 2x24V each). I could understand it as a smaller step up from a single Hicap, but ultimately I would instead look at a trade in of the single Hicap for a Supercap.
As to whether I would prefer a Hicap on the 282 and a Supercap on the SNAXO, as opposed to the Supercap on the 282 and a Hicap on the SNAXO, I’ve never done the direct comparison, so couldn’t say. However, if active then as the next logical step would probably be to a NAC252, having the Supercap on the 282 would make sense as it’s then just a head unit trade.
At the moment I will have 1 x SuperCap and 1 x HiCap to play with. Just where best to place them
Is it best to have the SC on the 282 and the HC on the Snaxo (changing from a FC).
Or the SC on the Snaxo and the HC on the 282, (obviously need to get a Snaxo Burndy for this).
What I want to do for now, is to get an improvement from the FC on the Snaxo. The HC is non DR and being serviced as ten years old. I am assuming that this would be an improvement, hopefully correctly.
Essentially, the main consideration is where to put the SC…
Because you haven’t got a Burndy your options are a tad limited.
Therefore if I was in that situation, then I would go for SC on the 82, HC on the XO…rationale being that at system level you are utilising more secondaries…then pour a glass of your favourite tipple and play some music
Then start saving for that second SC and SNAXO Burndy. (Or spend the kids’ inheritance).
Yes, I think suzywong is probably right here; without a SNAXO Burndy for your Supercap, you’re probably best off putting it on the NAC282 for the moment and the Hicap on the SNAXO.
It’s only been running for about 24 hours now, sounds good, but can’t tell much difference at the moment.
As it’s got new components inside, I’m assuming as with all new kit, it will take a while to settle in. Not sure of the time required, but keeping the system playing 24/7 and hopefully that will do.
All my kit stays on anyway, but will let it burn in.
