Hey Spleen, thanks for the tip. Just replying to this to highlight to others with a Sony Bravia and HDMI Arc set-up that the “Digital Audio Out Volume” is at default zero. Absolutely maddening, I was up on this forum till 3am having finally figured out I need to swap to PCM and not bitstream and then was stuck with absolute silence rather than the horrible noise that comes from 5.1 bitstream. If someone else is reading this with a Sony Bravia and HDMI set-up you have to:
Swap to PCM
Have Digital Audio Out at something other than zero
