My first Rega Saturn (Mk. 3) did the same. The replacement one has however been faultless and to my ears sounds quite a bit better than the CD5si, which in comparison, to my ears, sounds a bit opaque.
When the Saturn worked, I found it thin and bright by comparison in an all Rega system. I prefer the tonal balance of the CS5si. Admittedly it took me a while to get used to the different tonal balance of a Naim system after Rega. I kept wondering where the highs went to. The NDX2 and SPSDr really helped as an upgrade. Also moving to Chord EpicX cable was a shocking improvement.
Thats an exiting compare if you run moderate speakers in not large room.
I ran SN2 and SN2/HCDR and ended up to prefer Rega Aethos.
I even believe I read a guy preferred his Nait 50 to Aethos.
Many variants in game.
I would prefer the sound of Nait 50 over Supernait 2 but unfortunately the severe channel imbalance of the unit I have has made the Nait 50 obsolete (at least for the time being).
The SN3 is so good that Naim, after nearly 5 years in production, even after NC launch, have decided to give it a white logo, along with 500 Series. No limited production runs here. Why? Because it’s that good, they don’t want to let it go just yet - says it all really!
What he said.
Very nice
Loving the sideboard
That looks great. Is it a VESA stand you are using with the TV?
Thank you!
Yes it is a free-standing VESA stand for my 65" LG.
Out of curiosity, is anyone using a SupercapDr with their SN3? Worth it or almost overkill?
I’ve tried a SupercapDR with my SN3. The combo sounds better than a SN3 with HCDR, wider soundstage, more punch, bigger body (you may know what I meant). I cannot answer whether worth it or not since I have had a SupercapDR for my 252 anyway.
Thanks Bandit! Appreciate the feedback
Bandit, this is interesting to me. Would you mind sharing the % of improvement of SN3 bare, SN3 + HCDR, and then SN3 + SCDR?
I’ve thought about it but you’re the first I have read to distill the improvements so well. Appreciate your thoughts.
Hi all,
somebody with experience combining the SN3 (and by extend other Naim gear) with speakers of the Italian brand Zingali Acoustics ?
Visited a demo and heard the Quantum Array 2.8 and the Zero Otto (both equipped with a horn) in an Exposure setup (3510 pre and 3510 stereo power) and APL streamer and CD-player.
I was impressed by the sound of the easy to drive Zingali’s and will keep them in mind as a possible grade-up for my actual Monitor Audio’s. Home demo should be possible.
SN3 owner here with a SCDR / 250DR and Kudos 606’s. Sources are a P8 and Zenith Mk3.
Am tempted this year (although I said this last year) to upgrade to a 252 but I’m not sure how much better it could sound.
Well let me be the first to say your room looks gorgeous !!!
Gav
I have both the SN3/HICapDr and the 252/SCDR/250DR
I’ve said before that the SN3 is an absolute bargain in the Naim range and punches above its weight as they say , it’s an enjoyable listen
However the 252 is in a different league altogether , if you can try and borrow one from a dealer and plug it into your system, you will be surprised I’m sure
A lot better.
The SN3 is a real sweet spot in the range. But the 252/250 is where the real hi-end Naim magic starts. Given you have the SC and the 250, swapping the SN3 for a 252 would be a big step up and pretty good value I think.
