Dear All
I inherited a UnitiQute 2 from a friend of mine, and I was so thrilled to listen to it, and it’s wonderful that it received the recent firmware update too.
The only thing that prevents me from being at peace with my music playing setup is the really VERY annoying hum / whine the device emits. And, yes, I’ve read extensively on hum generally / toroidal transformers / “Naim hum” but my local Sevenoaks had a listen and pronounced it abnormal. OK!
So my options seem to be:
- Pay (if memory serves) £5-600 to send it back to Naim for a service and “presumably” this is a guaranteed fix but at an eye watering cost
- Sevenoaks recommended a local (Cambridge, UK) engineer called Mr Tech Guy / Resolute AV, who was very helpful and will charge me £70 to take a look but they clearly are in no position to guarantee anything, having not seen the unit, so that may be burning money for no reason
- Live with it, which is semi-viable as the noise is VERY positional and varies in intensity
- Explore some kind of mains filtering, e.g. a UPS / dedicated mains circuit
- Live with it
I’m a bit lacking in direction so would appreciate the wisdom of the very well informed crowd, if you’d be so kind.
BDD
