No not at all. The move to 2 and Sense certainly did that as did the early iterations of 2 but at this point my sense is that bug fixes are just bug fixes.
I am finding a slight improvement in clarity and microdynamics - it could be something else, of course, even just the drop off in business use over the weekendā¦.
No difference.
I was listening to the Atom HE yesterday and this morning and canāt tell any difference, but there has definitely been a nice little uptick on the 500 system. Back on that now.
Is anyone here using their Innuos with a latest generation Naim streamer (ND555 or Atom HE etc)?
Iāve set mine up to use the LMS UPnP bridge but am finding some local tracks are playing back with dropouts or skipping on to the next track.
Can anyone recommend a setting to remedy that?
No problems with Qobuz on the other handā¦
I am sorry I canāt help but have you asked Innuos about this behaviour?
My understanding was that the LMS plug-in was working fine for you.
I have had a few issues with Innuos Sense to ND5XS2 via Ethernet occasionally not responding to iPad commands, but not too often. Roon from my MacBook has performed better though. I use the the LMS plugin to play to various other devices including Muso when I listen via Sense.
Cheers, Ian
Iām using Sense app with my Chord system but have resisted the temptation to use a work around with my Atom HE, too many bad memories of drop outs using their iPeng/Roon solution. Hopefully they will get something working soon.
They tweaked various settings and it was working fine, but the latest version of Innuos Sense did a factory reset. I manually selected the the LMS UPnP Bridge and all was working fine, but now this problem has returned. Since theyāve become a bit more explicit about this being a user option that is not currently supported officially, I preferred to ask here about tweaks others may have found or remembered from the old setup.
FWIW it emerges that the problem with tracks skipping was a Naim beta FW problem that has now been resolved and had nothing to do with the Innuos FW or LMS settings. Anyone using an Innuos product with Sense and a Naim streamer with LMS set for the UPnP bridge will be fine with the release Naim FW.
Iāve just today updated to 2.0.9 and then 2.0.10 from 2.0.8. Having tried 2.0.8 for a month or so I would say 2.0.10 is as good as 2.0.5 which for me sounded wonderful. That is my only concern and I lived with having to restart the Sense App when it didnāt wake up.
Phil
