Inside NDS
You could use local streaming for better comparison.
Maybe best for you not to hear how much better local streaming is then :sweat_smile:
Looking forward to hear what you think of the 333 Streaming into the NDS :+1:
I heared it very similar (with nd555). I also like definition, speed and sharp details, but after this was associated with harshness due to … everybody knows it… I need detox with exactly the red wine signature. ā€žLess is moreā€œ:smiling_face:.
With bass I felt the same. Nds is less articulated but with more weight. I prefer that.
And! Let your ears adapt and the nds warm up
Nds and nd555 do have the same output level.
He does not know what he is missing. My comparison was always local streaming only. Therefore it might so close (or simply different) between nds and nd555.
So you compared only with Tidal ? Or also local? Because I have no doubts the 333 is better for Tidal.
Will he flip?
Ok, so I understand more. I suspect that with local you would have a less pronounced difference for speed and immediacy. But only a guess.
You don’t have a Nas?
Who? Flipper, the dolphin ?
No I don’t listen to music that way. I’ve left that behind.
You could use a Primare NP5 feeding the NSS 333. That should give you more relaxed presentation.
Have both connected to the Ethernet, swap from one to the other depending on what presentation you want at a particular time. You might find that which one you use is genre dependent.
Will @Blackbird flip his system, bring back the NDS, maybe even the 552/500?
  • Yes
  • No
0 voters
Very nice pictures! That is some craftsmanship :ok_hand:I have one question, is there any way to check if the springs under the brass plates are still fully functional without opening the NDS? I’ve got mine second hand and don’t know if the transit screws were used always when transporting. Everything seems fully functional at least.
I cannot see that being possible. It’s pretty easy to open it but would a spring not be in place then you would not be able to fix it yourself.
Shake it slightly and you need to hear them bumping without touching anything
You will hear a clonky sound when the brass plates move sideways and touch the metal pins that limits sideway movement.
Yes - you do. But when you shake it very careful the brass plate will move without touching.
I will have a go at this when installing some upgrades :smiling_face_with_sunglasses: 282 and 250 DR. Need to move the NDS anyway.
I thought as you mentioned more swapping, you either hadn’t decided or liked listening to both.
I like chips better than roast potatoes, but I don’t eat chips every day. I like roast potatoes with my roast chicken. Sorry @frenchrooster :grin:
Ok, so we won’t know. That’s life.
