Internet radio on my NDS is not working … station starts then stops almost immediately. I am working around it with Roon.
The issue is with BBC Radio 5 extra, well all BBC, except their podcasts. Radio Paradise is fine. Is this a known issue?
Yes it is, a few of us have found this, it seems to be something to do with BBC Stations only.
I posted about it here in Feb
I would suggest deleting your favourites, then searching again for the stations you want and save them again.
I tried that at the time but it doesn’t work.
This seems to be an issue with the new update and Roon when using a software bridge to give the legacy streamers Roon capability. The software bridge sits between Roon and the streamer and relay the Roon stream on to the stremer as UPNP.
Oddly it’s only BBC stations that are affected. As @Camphuw says it’s easy to work around by using internet radio on Roon.
I would like to be able to listen to the Great American Radio internet station as a pre-set asI I could before the update. Can anyone please help?
Thanks, I had just done a general search rather than look under a specific country. All sorted now😀
