Internet radio station broken
Hi all, I’ve had this issue in the past where a specific internet radio station died and the stream had to be reset by sys admins on Naim’s side of things. Well, I seem to be experiencing the same problem.
Radio Classique 99.5fm stopped working a few days ago. Today I went through the usual resolution procedure tricks to no avail. Deleted cache, unplugged the unit a few minutes, rebooting the router and even tried the full system factory reset (which turned out to be super annoying to get back up only to find out that the fm channel still does not work).
I miss my favorite classical channel, what else could I try? The station’s stream does work as usual when using their website.
There is an open topic:
Naim Internet Radio - Feedback & Requests - Part 15
specifically to report this type of issue which is monitored by the Naim Internet Radio team.
You may be more likely to get help quickly if you post the issue there.
Thank you, I had forgotten about this thread. I will post there about the issue.
