I ask as for the most part I’m still quite happy with the 272, however I’ve always felt that it’s streaming capability is a notch below physical media (CD, TT, USB) inputs.
I wonder if hooking up a ‘better’ dedicated streamer into one of the digital inputs would bring an improvement (e.g. from Naim or Auralic say), or would the 272’s DAC still be a limiting factor and this would be a waste of time and money?
People are using Primare NP5 network bridge with 272 and other gen1 network streamers and reporting improved sound quality as well as improved functionality.
£600 for the NP5 and ifi power supply.
I use one with an ndac. It’s very good, although the app isn’t fantastic.
It provides all the functionality that is missing in the first generation of streamers, including Roon.
It was inexpensive, 34.90 EUR only.
The DAC in the SuperUniti is strong (I prefer it to a few others), you can experiment with tweaks. To begin with you will have to decide if you prefer coaxial or optical.
I think it is an improvement and fun. I imagine even more fun in a 272.
Do you mean a steamer into an analogue inlet, or a transport into a digital input and utilising the 272 DAC, or either? Anyway, an Aurelic Aries as a transport might be a good option.
Yes it’s a thought, however wrong input combos on one of those…Have TT and phono stage, CDP and tape deck needing analogue inputs. 222 caters for different audience from me.
My experience too. When I had a 272/XPSDR and compared ripping and streaming a CD with playing it on my CD5XS into either the analog or digital inputs of the 272, I found streaming had the edge. The difference was not massive but a bit more air and clarity in the sound stage, for example, meant my CD player was rarely used.
I’m using a Holo Audio Red streamer feeding my nDAC. It’s nicely manufactured, a dense block of CNC’d aluminum carved on the innards. The list of supported services are on the product page, including UPnP, HQPlayer, Airplay, Qobuz, Tidal Connect and its Roon Ready. The Red has a quality LPS built-in and offers a plethora of outputs including SDPIF, AES, USB and BNC. In your case, you can theoretically feed the BNC output from the RED into the BNC input on your 272 for a more precise connection. This is how I’m doing it with a DC1 BNC-BNC to my nDAC but there are more economical models around; I have an Apogee Wyde Eye studio cable as a spare.
