Ok, thanks for explaining. Pleased it wasn’t accidentally something offensive.
I disagree on not having anything to do with it. As I said in that particular post the position of your head relative to the two speakers will most likely make a bigger difference than any tolerances between drive units.
It was just when it gets to the level of equipment we have and the special way they are constructed for very demanding owners and enthusiasts I wouldn’t after buying in to the quality expect not to continue consistent performance after repair.
I could see the point if it was just a random jumble of bits put together but all Kudos drive units and indeed components are selectively matched for performance as Naim used to do with their speakers.
I’m glad it wasn’t accidentally offensive.
TBH I think I’ll only be happy with what Kudos recommend to bring it back to its original state. I fear that’s going to mean a new driver in each speaker
Look, I’m not saying it’s a bad speaker. By all accounts Kudos are quite the opposite. But unless you’re listening in a purpose built room (and even then it’s debatable) other factors will make a bigger difference. Hence my advice to the OP to just repair or replace the driver and not worry. If for peace of mind he replaces both I fully understand that.
I imagine the SEAS drivers will be like the ScanSpeak drivers in mine which are sold in matched pairs … and will be more than £150 each … really sorry to see this @Stu299, can understand you being upset about this, hope you can get it sorted soon.
It’s amazing what cats can see. A couple of weeks ago we discovered we had a small leak coming in from around the chimney.
We didn’t notice the leak, no damage or wet patch on ceiling or carpet.
We only became aware of the leak because we noticed the cat staring at the ceiling, watching the drips fall to the floor.
