Search for this……
Can’t seem to find it - maybe I’m in the wrong region? Would be interested to see what tracks are on the list though
That Impulse track certainly shows that these speakers go low all while going warp-speed fast!
With another NAP 300 could I go active on the 606? Would I need anything else?
Just sitting here thinking, as you do…!
Thanks Toon! Some interesting stuff in here
You’d need an active crossover surely
nap300
nap300 PS
speaker cables
active crossover
crossover power supply
4 x shelves
sign off from the boss (good luck )
OK well that’s not happening then
The right SNAXO and a HiCap.
Grab a 500 instead - no extra boxes!
Would need a new rack.
A 552 on the other hand
Just slightly longer legs if you have a fraim
Google it, your browser will prompt you to log into Tidal. Do that and then add it as a favorite. You can then access it via Naim. Hope this helps!
I have the black 606’s. Fabulous speakers.
The 606’s are very forgiving when it comes to placement. I am in the process of moving house. Because of the narrow lounge in my old house (11’6”) the back of the speakers were 8” from the wall.
My new home has a 14’ wide lounge, so I will experimenting at pulling them forward a bit more.
I have the 606s in Oak and they are a superb speaker.
I initially chose them because I wanted a speaker that could be placed nearer to a wall.
They are partnered with an active Naim system of 282, 2x 250 and SNAXO 242.
As you can see, I use them with the grills on.
Got it, thanks Buster!
So kudos use streamed audio for their shows… I guess another nod to this medium being right up there with locally stored music?
It used to be the case that Naim recommended going active at 250 level before upgrading to 300 or 135 in the old days.
At the Acoustica show with 505s (2018?) they were using (if I remember correctly) Innuos Statement
Can’t find this playlist on tidal either.
