I had a speaker demo earlier this week of Kudos T505,606 plus Bower & Wilkins 803 D3s.
All three are superb speakers but my preference was for the T606s and consequently have a pair at home on demo.
Been listening for the last couple of days and they are bloody superb the bass is so tightly controlled the music just flows with a seamless, natural and effortless presentation.
They seem to be room friendly as well not needing as much distance from the rear wall as my Spendor D7s.
The picture does not do them justice they look better in the flesh and I am very pleased how they fit into the lounge they sound stunning.
The finish is Walnut finish but I also liked the Tiineo finish on the 505s I listened to but the dealer said the Kudos had stopped one of the finishes can’t remember which one and on which speaker ??
Probably have a bit of arm wrestling with the dealer next week to sort a deal.
They are 36 inches away from the left hand wall and 42 inches away from the right hand wall.The equipment rack is on the right, angled following the line of the bay window I can sent a picture tomorrow if required.
I would like to see it please. My personal thoughts are that they could come out a fair bit more and could be toed in. A little which could help sound staging. Your room is not too dissimilar from mine which has 808’s in it.
My 808’s sound Berger with loads of air around them but it’s just my humble opinion.
Quite strange how different rooms interact with different speakers when the dealer installed the 606s he placed them in same place as my Spendor D7s but ended up moving them closer to the back wall to get the soundstage right.
The soundstage on the Kudos speakers is superb.
The Spendors were 300mm away whilst the 606s are 250mm I was quite surprised how moving them back a couple of inches pulled everything together.
Wenger, I am very pleased with both the looks and sound of these speakers considering they are only slightly wider than the Spendors being the same height and depth the performance uplight is quite astonishing.
Not knocking the Spendors they are excellent at there price point
Kudos speakers will work close to a back wall but the room will dictate how much bass you get, in some rooms it could be too much hence the need to move them forward a bit.
My 808s work very well 170cm apart 65cm from the side walls and 35cm of the back wall with a very slight toe in firing down the room which is about 6m long and 4m wide. I am running with the grills on at the moment as we are looking after our daughter’s dog.
