No problems, hope this explains my thinking behind changing the Ethernet cables.
I wasn’t dissatisfied with the Chord cables and used a number of them including, Clearway, Epic and Signature streaming cables and, Clearway HDMI cable.
Very happy with the Linn / Kudos set up, but have been playing with the peripherals; cables, switches power supplies for a while now, which has been documented.
Following a long chat with Linn about Ethernet cables, they recommended bog standard Cat5e cables. Additionally, on this and other forums, had been reading about BJC and CatSnake Ethernet Cables and the positive reviews and comments that they been receiving. So , I thought that I’d give the CatSnake a go as they are easily obtained in the UK and are not too expensive. Also, they are one of the cables that are fully tested, whereas, Chord cables albeit nice, it’s difficult to find the actual spec of them.
Like you, I have read elsewhere about the lack of improvement with the Chord cables above the Chord-C range until you get into their top end cables. But to do the lengths I needed would have been cost prohibitive, hence the choices I had with my cables.
Upon receiving them, I found the build quality of the CatSnake to be very good and, although the cable was quite thick, it is very supple which helps in its dressing. I also got some Certified 8K HDMI cables.
For information, there is a HDMI Cable Certification App that allows you to check which standard your newly purchased HDMI cable conforms to. Simply scan the Certification Label on the packaging and it will tell you if it is genuine and what spec it is. Chord mention that their HDMI cable is certified. But when you check, it is UKCA Declaration of Performance Certificate for Reaction to Fire and Dangerous Substances.
As previously mentioned, I’m very happy with the sound quality of the CatSnake cables with a full loom from the Gigaclear Fibre Router through to the Linn Selekt. No night and day improvement over the Chord cables, but more importantly, certainly no worse, given the significant price difference between them. Mrs DG couldn’t tell that the cables had been changed.
I’m planning to keep the CatSnake cables as the sound quality appears to be very good and the build quality is excellent at a very good price-point.
The Chord cables can now be moved on to fund these cables and give me some change.
DG…
