I’m considering moving from my Ortofon 2m Black to a moving coil cartridge - likely the Dynavector 10x5 v2 (although open to other suggestions).
Any thoughts about whether to use this as an opportunity to shift to low output boards? I don’t know if either the MM/HO or LO boards is considered better than the other.
The N 322 boards with the 10x5 were a bit underwhelming on my Nac72.
I had a pair of 323 serviced and changed to the E type as suggested above. Great combination with the 10x5 and 72.
No, not at all. What I mean is than with N boards a DV10X is quite a low quieter than CD - volume wise. It works fine - you can just get a bit of a surprise when swapping between inputs…
AFAIK, the DV10X is always high output MC.
But the DV20X does come in both low and high output MC versions.
(I have checked Pear Audio’s website, who distribute Dynavector in the UK.)
