Merry Xmas and a happy new year to all! I just require some quick knowledge from the group!
I ave a Nap 250 Dr on the way to go with my Supernait 2, Hicasp DR, ND5XS2, Chord Qutest and MCRU power supply. Unfortunately I’ve ran out of wall sockets.
What is a good, cost effective mains block / main extension that I can use to increase my power sockets.
I have been looking at something like this, olsondirect 6-way-13a-unswitched-socket-neon-13a-plug-pdu
Hi, you’ll see that there are several threads on this already if you use the search function. One of the most cost effective and possibly best solutions would be to make your own. Have a look at what @Skeptikal has done here:
Have a look at the thread entitled ‘Mains Power Cords’, which is currently live. This discusses, among other things, a Grahams Hydra, which is also a great solution. I used one of these many years ago.
All the posts (so far) have suggested good quality sensible extension block/strip ideas, but also mentioned a DIY solution, that can be interesting & rewarding, if you have the tools & skill available.
I made my own, primarily sized to fit inside the bottom section of my equipment rack
(also DIY), this enabled it to be made compact/bespoked form, the same can be applied to any/all individual setups if you take the DIY route.
Starting from the wall plug …
… Furutech FI-1363 13A plug
… H07RN-F 4mm/2
… power board with 3x MK Unswitched Double Sockets
(plus 1x switched double for other purposes)
Internally wired in radial (star)
Neither do I, I have two unused outlets.
SN & NAT go into separate unswitched doubles and the unmentionable PSU’s share the third.
The switched double (originaly used to power a Rega & its Phono stage) now has an Isotek Evo3 (noise & surge supressor)
I would avoid anything with a neon or led light on it. Either that or remove the light and any associated circuitry from it. I’ve found that these can generate electrical noise which creates an audible hum through my speakers in the past.
