I had 3 different 52’s back in the day. One only lasted a day as it was very poor, and my lovely pots 8, 82 sounded much better.
The next one i had sounded better and was the twin board version, still an early one but it was nice.
I finally finished up with a very late model with all the updates naim did to the 52 along the way. Single board design now and it was better than the previous one.
But what i am trying to say is, if you a have a nice one then you could well be better keeping it, as especially with vinyl being a main source fo you, you could well find the 552 for the outlay not a big step forward, and more a side way step.
But only you can decide that when the time comes, but as said i certainly wouldn’t be sitting there thinking much about it.
Mine is a 1993 version, so fairly early. It’s been looked after alright. From the off, unserviced it was noticebly better than my wonderful 82 which I had for 5 years. Then I got it serviced and it has come back sounding better. The POTs 8 upgrade was done later. It has K phono boards which I have left in. I know many say it sounds better if you take them out but I am keen to keep it all original.
“I often listen to music loud. I found the 250CB used to cut out.”
Blimey, you ran your 250CB hot enough to cutout… that’s impressive. The only time I had an amp run anything like hot was when I had a little Creek CAS4040. That was a while ago…
Many many times @Bokermonz. Never had a problem with 135s on that front with the fans. The NC has fans.
Have managed to kick in fan on 500DR as well even though it has heatsinks. I had it running hot!
It’s certain types of music that run amps hot. If you play jungle, techno, drum and bass loud for sustained periods it runs them hot.
I find listening to loud rock it doesn’t run as hot as there are quieter periods in the music.
Hi Dan,
I also had a 52/500 and my initial thoughts when getting the 552 was that I had lost some of the sweetness, whatever that is, but then I got used to it. Given that time again, I would have bought the Townshend Podiums first, as they increased the transparency and inner detail I was after, not to mention the effortless driving of my Titan t88s.
I too now have a full 500 system, but alway like to read about fellow forum members who are on a journey to/or reduced their box count, but now take with them the wisdom of what truly does it for them.
It’s an expensive learning curve.
As others here, don’t ditch the 52 too early the gains maybe elsewhere and you may, as they say “through the baby out with the bath water”.
Whatever, I always enjoy reading your posts and good luck on the health front.
Russ
Thanks Russ, appreciate you and Dunc both saying don’t rush to ditch the 52.
I thought I’d need a Radikal 1 or 2 for the LP12 but the changes I made to tonearm, cart and phonostage have made such a difference that the LP12 sounds very sweet. I had the Lingo 1 serviced and the mains inlet changed to non filtered type. It all sounds very good.
And the changes to the streamer with adding the ND5XS2 to the NDS with 555PS has worked very well. I don’t feel the need to change to ND555 right now, although it would reduce box count by one.
So I don’t find my system lacking particularly. I guess the Radikal 1 or 2 would be next nevertheless.
I want to see how good my source can be.
I had the phono boards in the second 52 i had, i did remove them both but can’t say i heard a difference. But they just push onto the boards so very easy to remove and replace if needed.
But if you aren’t using them, then i would remove them as for one it help keep the life in the phono board’s, and secondly it certainly can’t hurt removing them from inside the box as it’s less stuff going on inside to try and power, plus give off nasty things to effect sound quality off the rest off the things going on inside the box.
I’m going to leave them in there. I love the 52. I may keep it. I may not so will leave it original. I may even want to use the phono boards, but doubt it.
The system is sounding great. Just fitted new blind which was a complete mission without taking system apart!
I just took the phonostage and LP12 out when fitting. Couple of balls dropped from Fraim which you expect!
Need to fit blind valance but a job for another day!
I sold nait 1 and 42 (both spare) today.
Nap 500 is my main target for 2024 … hope he will come soon. Best with DR … if not - also ok. I let one pass some time ago for a steal price…damn
When the cable is hanging free down this equal gap is hard to manage.
Just to let you know the 500DR sounds mighty fine with the 52. Taking advice on here I am not rushing to a 552DR.
So many views on here saying 552DR is more important than a 500DR but with the 52 maybe it’s the exception!
I ran my 500 for about a year with a late model 52 and thought the combination was great. Going over to the 552 was not the huge jump I was expecting. However, little tweaks like SL interconnect, Din/XLR’s and Powerlines started to reveal just how good the 552 can be.
The 552 is a more ‘mature’ sound with finer detail, better instrument timbre, more spacial clues giving better depth and image width but it takes time and effort to get both working in perfect synergy. A 500 systems is very very sensitive to stuff that you’d normally think completely insignificant, so take your time to understand these effects and enjoy the music and the journey in the mean time.
You’ve opted to take the red pill so rest assured at some point in the near future Kansas is going to go bye bye!
Get the 500DR. I got one for a steal. Very very pleased with it I have to say. Can’t stop playing music.
It’s very interesting to hear from guys who went 500 or 500DR first rather than 552. I am very happy with my choice. It all sounds very wonderful.
I have taken the red pill so let’s see how far that goes!
I am loving the journey. This is what I wanted, to be pushed mentally and emotionally with my system.
It’s not simple. It’s not like you plonk a 500DR in and everything is wonderful. It’s how you can get the best from it. Careful cable dressing. Considering different speaker cables. Do I go 552DR or leave it.
I will let things settle. Sell off my unused kit and give it the space and time it deserves.
I have been absolutely killing my system today. Playing vinyl all day and now upping the tempo with techno and drum n bass on the NDS. Just went outside to see how loud it is on just over 9 o’clock. It is seriously loud out there!
Happy Sunday!
I hope you have good neighbours!
Is your house detached?
Just thinking the same
It’s link detached by garages. Got dopers on one side who are cool and feds on otherside who are cool as long as music isn’t played too late.
Wow just playing some stuff now and this is where 500DR comes into its own. Tiesto, 50 cent. Bass is unbelievable!
Turned it down and fan was running on 500DR and running redhot. This sounds really good.
500 was formulated to partner the 52. It’s a perfectly natural combo
The speakers are able to handle alot more power with the 500DR. Previously the speakers would clip above 9 o’clock. Now you won’t want to play it much over 9.30. It is seriously loud with Sopra 2s.
But sounds fantastic.
Might ermm possibly need room acoustics! Dangers of a better and more powerful power amp. This is what I wanted!
