I leave mine always on with screen always off in ‘dark mode’ - I like dark mode!
The HiFi is also always on - except when thunderstorms or I’m away for more than a few days.
DB.
DB.
a person transferred my library from the serve on an hdd external drive. they are in Flac. But in this hdd , there are also photos.
If i transfer now from this hdd drive to my melco, will the melco import the photos files too, or only the musical files ?
If you copy the files complete in their folder - all at once - into the Melco folder then it will all be there.
So select the folders you want from the HDD that has them - then ‘paste’ them onto the location you want them to be accessed on the Melco and it will all be fine.
You can test it by copying just a music folder and content and checking.
You can also delete stuff later from the Melco you don’t want - it behaves just like a remote access drive on a network computer, because that is essentially what it is.
DB.
thanks DB!
I thought you’d prefer darke mode.
Dark Mode was the first ‘option’ years ago my Dealer demonstrated to me when they first got Melco and liked what it did. It is a small effect similar to the light-off option on Naim boxes - you either hear it as a little extra HF smoothness or not - but in evening it is another display I don’t need to peripherally see.
DB.
i finally got my unitserve cds rips on my melco. Vs the dbpoweramp rips by my dell xps 15 2010 pc ( not used cd drive inside since i bought it), the unitserve rips are a bit nicer and natural sounding.
So glad to have my unitserve rips again !
Overall, since 6 days run in, the melco n1a2 is better sounding than unitserve / linear ps. The sound is cleaner, a bit less grainy, more natural a bit too, with sometimes clearer details.
I would say the difference is like between a powerlite and powerline.
here the famous Miles Davis box set that couldn’t be ripped by Dbpoweramp or Exact Copy.
The unitserve could perfectly.
