Milty Zerostat 3
I’ve got one of those boxes…
Last time I looked I’m pretty sure there was also a Sure V15 cartridge…
WOW just looked on ebay what people are asking!
I found my dad’s Dust Bug when cleaning out some stuff. I remember that thing from my youth!
Re-checking… There is also a Naim remote (I use a newer one, which came with my CDX2), a Discwasher (?) stylus cleaner, a 1/4" to 3,5mm stereo jack adapter (which I made) - and some 1/2p pieces…
Wish I could remember what these little stickers were supposed to do…(in the smallest of my three boxes of odd bits & stuff!)
Are the Stickers not for 52/82/102 Input switches…?
No idea, Ian. IIRC, I got them back in the 80s/90s from either Sound Org or Graham’s (or not!).
At the time, I had 32/SNAPS/250 so I think they were some kind of tweak for something else, maybe the Linn as I didn’t have a CDP then. I’m not sure they weren’t just some gimmick or were actually useful.
Some sort of Witchcraft then… :thinking:
Best wrap in foil & bin them…
I’ll wait for a full Moon, just in case…
And have an incantation or two ready.
Can’t be too careful… :+1:
Garlic… Wooden Stakes… Then zap them with your Zerostat… :rofl:
Ah, but the blue one or the original white?
I don’t have any garlic - will try a dried prune or two!
Mine is an original - and is White…
Yes…White Magic…should do it.
Now where’d I put my Toad…?
Like some others I found the Zerostat 3 to be totally ineffective. I now use the Furutech Destat 3 which does work, albeit at a very high price.
@GerryMcG
Out of stock at Music Direct. Thanks for the tip. Will chase it down.
You can buy manual, non vacuum based, cleaners, just a plastic bath and brushes and cleaning solution, about £40-50. I use one, very effective against static.
Laskys now your showing my age! That’s not a name I have heard since childhood.
Don’t forget Cleartone too :slightly_smiling_face:
I have one of those. It’s does a decent job for the money, but can only do a few at a time as you run out of space to dry them.
