i can not receive any audio from Progulus Metal Radio for a couple of days now.
However the naim app still shows the name and the cover.
I also tried to save a new search for PMR, but without success.
The naim app shows name, cover but there is no sound.
All other radio stations are working fine.
What to do?
In the PMR forum it was announced that there has been a change of the stream address.
How to update that?
The new direct stream link is http://149.56.234.138:8063/stream
Looks like you have a 1st gen streamer. Depending on the format of the new stream, it’s possible that old firmware would not support it, so check that your streamer is on version 4.8. If it still doesn’t work it may be incompatible. Perhaps @Stevesky can advise?
On Airplay compatible devices you could, for now, cast the stream from a phone, but that is no use to you with an NDX. Maybe try a USB connection if you have an iOS device.
I have the same problem when I try to connect via vTuner via browser.
The Mu-So is on Firmware 2.0, my NDX has the latest updates.
The NDX was several times for service, but this is another issue.
Maybe following example helps:
Streaming from webside is working:
But the comment “Depending on the format of the new stream, it’s possible that old firmware would not support it,” makes me nervous. Are there any streams which are not avaible for 1st gen streamer from naim? Should not be there a new software for it?
I don’t think vTuner respond to individual support requests, but Steve, Naim’s software man, who I flagged earlier can contact them so he may well be able to resolve this.
If I play the stream on my iPhone I can cast it to my Naim streamers via AirPlay. This should work on your Muso?
When you log into vTuner what MAC address do you use? You need to create a separate login for each device using their individual MAC address, so make sure you are adding the station URL to the correct device.
At vtuner there is a form to fill in for suggesting stations. I tried that. Lets see if they react.
Well PMR played fine now for months. But at Sep. 6th they changed the streaming address. I think this caused the error.
Sorry, i find other radio stations with the iphone music app and radio but not PMR.
Apple support pages are not very helpful.
It only works when i am using the URL in Safari. But this cannot be the solution. This is not satisfying. It will work for some days, but not longer. There is no info goiven about song and band.
This works for me and I can then cast it to my Muso and see what is playing. Not the best solution, but at least it would give you something.
Hopefully Steve will pick up on this at some point - he can usually resolve these issues.
Dear Chris thank you very much for your support. Much appreciated.
It works in a browser, on my PC and also iphone.
It is a good workaround until it is fixed.
Do you have a NAS on your network? I ran a legacy streamer for years and found streaming lossless radio stations via UPNP and a playlist to be easier and has better SQ. You need to run mimimserver and save a playlist file on your NAS though. Much easier to update than vtuner. I can walk you through the setup when I’m back at the house if you like. Will even share my playlist file to save you the work.
Until they update it add it as your oadded station. You wil need to login on https://naim.vtuner.com/ and use your device mac address. I am not sure email and passsword works.
