I’m after a bit more advice - that’s probably already been given previously but I can’t find it!
Anyway at the moment I have a NAC 122X pre and NAP 200 power and in between I have a FlatCap XS - I now have the opportunity of swapping to a NAC 202 and my question is can the FlatCap be used to power the 202 (and yes I know the 200 can power the 202) but I want to keep the FlatCap because that will power the StageLine that’s arriving tomorrow (at least that’s what I’m hoping for if I’ve done my homework correctly)
Sorry to be long winded - thanks in advance for any help
I’m new to Naim but just love what it does to the music.
I’d seen somewhere that the FlatCap could power 2 bits of kit at once hence the decision with adding the StageLine - but after looking through all the manuals I could find on the old tinternet I couldn’t see a connection diagram putting the FlatCap between NAC 202 and NAP 200! So I was rather unsure. I think I’m right in saying that the HiCap seems to be the preferred option between the two and that’s something I’ll look into later.
You can do that. Bear in mind that the ideal match for the 202 is a Hicap DR, not a Flatcap, which is little better if any than the preamp supply in the 200, and that you’ll be wanting a Napsc to power the digital stages. The Stageline will probably sound better powered from the Aux 2 of a Hicap powered 202 than from a Flatcap.
If it was me I’d be getting shot of the 200 and getting a Supernait 3. It has a built in phono stage and DR power supply for the preamp. One box instead of five.
I see you’re using a system slightly similar to my own 152 instead of 122 - may I ask the silly question as to where is your StageLine getting its power?
Thanks - it’s all a little complicated for a simpleton like me - I know that it’s worth it tho - I’ve been absolutely amazed just how much better my music sounds after switching over to the dark side - my old mf stuff just didn’t grab me the way Naim stuff does. I worked out the other day just how much I’ve spent over the years on other brands - I could’ve had a 552/500
That’s going to be the plan I think - but it will have to wait a little now - finances a little low shall we say - FlatCap will have to suffice for now at least!
Pulled the plug on the 202 it arrives on Friday - StageLine arrived today - sounds awful - noticed cartridge is practically sitting on the vinyl - I think the cantilever is giving up - still it’s about 12 years old so it looks like a new stylus needed - think I might put a LVB 250 in the 2M Black - when funds allow at least. Ggggrrrrrrr!
