Hi, my 272 has started to randomly mute itself, have updated to latest update, factory reset etc, this was occurring before the update which I thought might fix the issue.
Any ideas?
Thanks Terry
Try turning off the mute option in settings could be a failing logo sensor on the 272
Thanks will try it
I think the “failing logo sensor” is what happened to mine. I had a replacement unit as it was only a few months old.
Thanks will see what happens
