BubbleUPnP server can use the Linn, Linn Kazoo or Lumin apps to control a Naim streamer.
I used bubblesoft for years to stream 24/192 Tidal and Qobuz with my SU. No cost. The Linn App works great with the SU and I still use it with my 272. Sublime SQ with Qobuz.
Yes, BubbleUPnP gives you the option to do that. You can then end up with lots of options for renderers in the BubbleUPnP app, which might be a pain depending on how many you choose to interact with regularly. You can always hide them in the app options menu though
Yes I know bubble can do that with current gen streamers, I was wondering if the option was available for older streamers?
Yup. Here’s my UQ1.5 (a unitiqute 1 with a board update!) presented as an OpenHome renderer
It worked identically before the board update too.
It might help technically, sounds like the main issue is making the payments from a country Qobuz do business in though. Happy to help troubleshoot the app and server side if that would help them. I run the server on a Mac mini, it’s run faultlessly since install. Installing wasn’t too painful if I recall correctly
