The original Tidal API that we use is http only and it exchanges login details in an unencrypted form. This wasn’t something of Naims making (we and everyone else had to use the API as defined by Tidal in 2014), but the world has moved on security expectations wise, even though its not protecting a bank account or similar.
I do have some good news though - we have new code in public beta for Muso Gen1 & green screen Hifi products that updates them to switch them to more secure protocols and principles (OAuth2, TLS1.3) to ensure they have many more years of life in them.
As it’s in public beta it’s quite advanced, but at this stage we can’t give full details of what is in the update & when it will go live. It’s all good stuff though and will make various on the forum eat their hats who have claimed we would never do an update!
I wish I had seen your very helpful posts earlier. I have the same set-up Netgear ORBI mesh with Netgear Armor. Unfortunately, Netgear Armor identified my ND5 XS as an “Asia Pacific Microsystems thermostat” (I kid you not).
I pulled my hair out for days trying to figure out why I could access TIDAL on my Mu-So speakers but not my ND5 XS. I whitelisted the “thermostat” and I am happily streaming TIDAL again on my ND5 XS.
I hope the beta discussed will also include the ND5 XS!!
You don’t need a wired connection to the laptop. WiFi is fine as long as it’s reasonably good. Also you can’t brick the streamer if the update fails because of a WiFi issue. You can always start again because the legacy products boot from a piece of resident code that isn’t over-written by the updates.
Best
David, very useful info thanks. In that case I may try taking the mac to the streamers, as it is only the mains cable to unplug for that. Unlike the 272 that has all manner of analogue, digital, optical, PSU’s attached! Thanks.
@easeback1 you have convinced me to give wireless a go when this new update arrives. Good luck with the NDS should be a brilliant source. I think if you want to use Tidal, you may need 4.7 so it works properly.
Enjoy.
I can confirm David’s point that doing the update over WiFi is generally fine, over the years I must have done 20 or so updates without the Ethernet cable and never had one go wrong.
Amen to fixing the bug that complicates playing DSD tracks larger than 1 GB on first-gen streamers (NDS, NDX)! While this doesn’t manifest itself for much outside of the long movements of late 19th-century symphonies, it is a little disappointing that a company that sweats the details like Naim hasn’t been able to fix this bug.
