It appears to be the case, before your ownership I wonder how the Allaes have been cared for over the years, perhaps located in a humid room?
Also the damping weight is missing for the main driver on your picture, unless you have removed it?
Well my country is humid 365 days so the foam is bound to disintegrate quick, about the damping weight. It is still there, hidden under the white cloth thing.
If you look at the woofer pictures SeanF and I posted it shows a damper, foam strip hot glued to the woofer with two metal strips, your picture just the foam strip.
The mass dampers is still there
This pic is another side, the previous pic has the mass dampers there, shiny looking. The previous pic has the mass dampers looked so close together that it looks like there is only one but actually there is two.
Ah okay, must be a trick of the camera.
Goods news then
Is it possible to remove the old hylomar with isopropyl alcohol 99%? As i plan to redo the foam next month or so
They are indeed bolted Richard - there are 4 prong tee nuts on the inside of the cabinet. So they should remain captive when the bolts are removed.
Neil.
No. I would use lighter petrol or white spirit to remove the old using a rag, use IPA before the re-application of Hylomar, then use a medical syringe when âreapplyingâ the Hylomar.
Donât they have a syringe included already?
I would be inclined to steer away from using white spirit, as it doesnât evaporate as fast - you donât really want it soaking into the exposed cabinet material around the aperture, it may swell.
Neil.
I had a friend aswell, told me that I donât need to use a torque screwdriver if I donât want to spend more but make sure that it is tight but not overly tight.
Hmmm, then what do you suggest. I also googled and found that acetone should not be used aswell, as it can damage the wood. Iâve seen some people said denatured alcohol works aswell.
Lighter fluid and meths may do the trick.
I think liquid lighter fuel/meths would work well to get rid of the worst of it, then IPA before reapplication.
Just donât drench it, apply the products to the cloths.
Neil.
Hmmm okay, do you think there is a chance that the hylomar easily peel off without taking the veneer away
If I do reapply the hylomar, do I apply it to the cabinet or the driver itself.
Once the initial seal has been broken it should yield quite easily, concentrate on one corner applying some pressure via the basket from the inside. Be sure to âgovernâ that pressure with your other hand on the outside of the cabinet.
Neil.
Ah I see, thanks for the guidance.
The cabinet, itâs much easier to control the size of the bead. You will probably be able to follow the witness marks in the veneer to ensure youâre in exactly the right point where the two surfaces will meet.
Neil.
